onnxruntime-web
1.22.0 • Public • Published
ONNX Runtime Web
ONNX Runtime Web is a Javascript library for running ONNX models on browsers and on Node.js.
ONNX Runtime Web has adopted WebAssembly and WebGL technologies for providing an optimized ONNX model inference runtime for both CPUs and GPUs.
Why ONNX models
The Open Neural Network Exchange (ONNX) is an open standard for representing machine learning models. The biggest advantage of ONNX is that it allows interoperability across different open source AI frameworks, which itself offers more flexibility for AI frameworks adoption.
Why ONNX Runtime Web
With ONNX Runtime Web, web developers can score models directly on browsers with various benefits including reducing server-client communication and protecting user privacy, as well as offering install-free and cross-platform in-browser ML experience.
ONNX Runtime Web can run on both CPU and GPU. On CPU side, WebAssembly is adopted to execute the model at near-native speed. ONNX Runtime Web compiles the native ONNX Runtime CPU engine into WebAssembly backend by using Emscripten, so it supports most functionalities native ONNX Runtime offers, including full ONNX operator coverage, multi-threading, ONNX Runtime Quantization as well as ONNX Runtime Mobile. For performance acceleration with GPUs, ONNX Runtime Web leverages WebGL, a popular standard for accessing GPU capabilities. We are keeping improving op coverage and optimizing performance in WebGL backend.
See Compatibility and Operators Supported for a list of platforms and operators ONNX Runtime Web currently supports.
Usage
Documents
Development
Refer to the following links for development information:
Compatibility
EPs/Browsers Chrome/Edge (Windows) Chrome/Edge (Android) Chrome/Edge (MacOS) Chrome/Edge (iOS) Safari (MacOS) Safari (iOS) Firefox (Windows) Node.js
WebAssembly (CPU) ✔️ ✔️ ✔️ ✔️ ✔️ ✔️ ✔️ ✔️[1]
WebGPU ✔️[2] ✔️[3] ✔️
WebGL ✔️[4] ✔️[4] ✔️[4] ✔️[4] ✔️[4] ✔️[4] ✔️[4]
WebNN ✔️[5]
  • [1]: Node.js only support single-threaded wasm EP.
  • [2]: WebGPU requires Chromium v113 or later on Windows. Float16 support requires Chrome v121 or later, and Edge v122 or later.
  • [3]: WebGPU requires Chromium v121 or later on Windows.
  • [4]: WebGL support is in maintenance mode. It is recommended to use WebGPU for better performance.
  • [5]: Requires to launch browser with commandline flag --enable-features=WebMachineLearningNeuralNetwork.
Operators
WebAssembly backend
ONNX Runtime Web currently support all operators in ai.onnx and ai.onnx.ml.
WebGL backend
ONNX Runtime Web currently supports a subset of operators in ai.onnx operator set. See webgl-operators.md for a complete, detailed list of which ONNX operators are supported by WebGL backend.
WebGPU backend
WebGPU backend is still an experimental feature. See webgpu-operators.md for a detailed list of which ONNX operators are supported by WebGPU backend.
WebNN backend
WebNN backend is still an experimental feature. See webnn-operators.md for a detailed list of which ONNX operators are supported by WebNN backend.
License information can be found here.
Package Sidebar
Install
npm i onnxruntime-web
Weekly Downloads
233,690
Version
1.22.0
MIT
Unpacked Size
94 MB
Total Files
495
Last publish
Collaborators
  • eire
  • onnxruntime
  • zuzhao
